OPCUA server : Support for global discovery server?
Hi @Kevin.Herron,
Is there some plan for Ignition OPC-UA Server to support GDS "OPCUA - global discovery server" ?
https://reference.opcfoundation.org/v104/GDS/docs/
https://documentation.unified-automation.com/uasdkhp/1.1.1/html/_l2_ua_discovery_connect.html
Possibly after OPC UA 1.05 support is done.
To be clear, we’d be adding support for registering with a GDS, not acting as a GDS.
Hi @Kevin.Herron,
Still in the roadmap for 1.05? With 8.3.0 or later?
BR,
Milo 1.0.0 is out, so that targets OPCUA 1.05, it will be interesting to see when that is update in Ignition itself.
Yeah, it should be in the beta... I'll put the PR up for it today. There's an advanced setting on the server config that, when enabled, allows a GDS server to manage the Ignition OPC UA server certificate and trust list. All you have to do is enable this setting and configure a user that has the "SecurityAdmin" role. The rest is up to the GDS.
There shouldn't be a ton of visible changes.
Support for the DataTypeDefinition attribute is a big deal.
There should also be a full mapping of all OPC UA built-in datatypes, structures, corner cases with Variant and ExtensionObject etc... to Ignition types. Many of the types that didn't map to the obvious corresponding Ignition type just didn't work or were toString() values before.
Hi, are there any more details for GDS support. I wasn’t able to find anything in the documentation and also not in the advanced settings.
Hmm, well the config setting exists on the backend, but it doesn't exist in the UI right now it seems :slight_smile:
I'll see about getting that fixed.
You could modify the config file on disk and set advanced.gdsPushEnabled to true in the server's config.json.
This has been addressed in Ignition version 8.3.5!
