Open an Intranet Address from Ignition
Good Morning,
I have been asked to create a page that can link to an address on our local network. I have looked through the forum and have read about a Web Browser Module. is this necessary to launch from within the local network also?
The Web Browser module is for embedding a website inside your Vision application. If you just want to launch a browser with a URL, it is not needed.
Take a look at @paul-griffith 's response in this thread.
Hope this helps!
From a “Home” window in our application, they have requested a button to open another window that will show a schedule that is on the local network. On this window there will also be a button to get back to the “Home” window.
This is possible without the web browser?
I did not see where to put the Local Network address below.
http://v-web_PORTAL/main_blend_xx.aspx
I presume this is referring to Perspective since Vision would be an application rather than a web page. If this is the case, you can use a link component or a button to navigate to your intranet address
This is for Vision. I was referring to a Window in my Vision Application. Sorry for the misunderstanding… I want to open the address from above inside of My Vision Application on a separate Window.
You need the web browser module to do this.
OK. That is what I was wondering. I noticed that there has been some confusion on some posts where to find the module. Can you direct me to the location of the Module?
Thank you…
https://inductiveautomation.com/downloads/ignition/8.0.14
It’s in the modules section. Change the version or check the archive tab if you’re not on 8.0.14.
Thank you for your assistance. Found it easily.
