Open file in perspective
Hi togehter,
I try to open a htm file, which is located on a network drive.
I can reach this network drive from my local pc, but also from the ignition gateway server.
I know that it is not possible to reach files from the local pc, but it is possible to open the file, because it is reachable from the gateway server ?!
It is not possible to copy the file to the gateway pc, because I need to reach hundred of files depending on some parameters.
Is there any way to open this file?
Thank you in advance
Inken
The easiest way to this is to run the optional WebDev module and programmatically read the files in its scripts.
