Open Pop Up Window when an alarm is triggered
How to make a trigger to automatically open a popup window when an alarm (critical priority is triggered/active)
I already play around with Alarm Event scripting at the tag I set the alarm but still the pop up window still not appear when the alarm is triggered.
here is my script:
if alarmActive(alarmName,'CriticalAlarm'): system.nav.openWindow('POPUP_CriticalAlarm')
p/s: I am using vision module
Have a look at my post about value change script open a popup. You can use this tag value changed for your alarm.
Open pop up with tag event script ( Valued change) - Ignition - Inductive Automation Forum
Perhaps this post will help:
Open Window in script tag changed
I think it's different. I am using vision module. You use perspective right?
Ah. I didn't notice you were asking the vision. Please ignore my previous cmt
