I have a table and depending on which cell is click on, I would like a certain popup to open. I “think” this would use an if then but I can’t get the syntax correct and I get errors. I do have the below and no matter which cell is click, it opens the popup which doesn’t surprise me because I know I have something incorrect.
So in this example if I click the cell in row 3 and column 2 then I would like Test 1 popup to open but if say I click the cell in row 1 and column 1 nothing would popup in this case.
(event.source.selectedRow==3 and event.source.selectedColumn==2)
system.nav.swapTo(“Fueling Site/Test 1 Popup”)
I'm not sure how to quantify "progress", but you can use this:
if (event.source.selectedRow==3 and event.source.selectedColumn==2):
Also, it's best if you briefly describe your issue in the topic title, as opposed to something generic like "I need help". And if you manage to solve your issue, providing the solution for others who may have the same issue in years to come
In a table, I have a column rendered as a view to show a button. Clicking on it opens a popup with more details. It didnt worked well at first, but it does now with release 8.1.1.
For using the OnCellClick, is there a way to push the actual cell data into usable info for the popup?
e.g. my table has rows with numbers 1-5. When someone clicks onto these rows, popups 1, 2 etc would open when clicking onto the respective numbers.
Is there a way to push those numbers onto the popup configuration? I can browse properties but am not sure how to refer to a specific row of data, even using the props.selection.selectedRow, which gives you the selected items row number.
Update: I’ve changed to using a script instead and it has successfully pushed through on click. However, for some reason, my parameter is not getting input and the default value has been taken instead. I had written the following:
