We have a docked window that has a set of buttons for navigation. Sometimes when navigating to a screen and then navigating back to the screen you just came from the button that takes you back to that previous screen does not work. They are all set up with the standard open/swap configuration with the swap selection checked. Just wondering if anyone else has seen this before. We got around this one a different project by using a script to close the active widow first and navigate to the selected window. I would rather not have to do that again because it should work the way it is set up.
Double check. What you described can happen if one of them doesn't use swap.
Good catch! I checked all the buttons on the docked menu screen, and they were all set up correctly. However, there is a big menu screen, some of those were not set up correctly. I ran through a screen selection that included selecting a screen on the big menu, and discovered I had better check those buttons as well. Thank you for the assist!
