Hello everyone.
If anyone could help me.
I want to open views/windows on Perspective when any tag (boolean) has change its value from OPC Tags. I was trying on tag editor window with the scripts of this forum but i cant do it.
There are many posts already, perhaps this one will be helpful, Show a popup in perspective on all clients if a value changes
By the way, you don't have any script.
This seems to be a copy of your posts on System.perspective.navigate doesn't work on session custom property tag change script - #6 by Francisco_Ochoa which already has a couple of answers.
Do you have a question?
can you help me with a same problem?
i want to open VIEW when a tag change value(boolean) but i cant do it , i tried with any examples of here but doesnt work
Welcome to the forum, Francisco.
For anyone to help you, you need to show,
Otherwise everyone is just guessing.
Tags are outside your project. Tags know nothing about your project. Tags don't know if your project is open or not. Tags know nothing about session properties in your project.
Try this:
That, and you got your indentation wrong, as the red squiggle is trying to tell you.
The last point onChange event should be write on Expression?
No.
session.custom.openview.Make sure that you are consistently using one tab character to indent, not any mixture of tabs and spaces. You can right click in the script editing area and select 'Appearance' -> 'Show Whitespace' to see the invisible indentation characters.
might. Looks like you can't.
Your for loop isn't indented to be part of the def.
i move it but its the same error
