I am have trouble with opening windows at start up of a client. I have a client start up script to open windows based on the log in user name. No windows is checked “Open on Startup”.
The trouble is that a window named “Overview” is always opened when the client is started. But the Start up script is not opening it.
There is a Window “Overview” in my project, and if i change the name of this window it does not opened at start up, and I got no error message.
The only error I can find is in the client(appears on every startup) Help - Diagnostic - Console:
02:29:55.356 [AWT-EventQueue-0] INFO vision.App - Starting Up…
Exception in thread “AWT-EventQueue-0” java.lang.IllegalArgumentException: Resource specified is not a window (fpmi/Navigation).
- at com.inductiveautomation.factorypmi.application.model.WindowCache.getWindowInfo(WindowCache.java:169)*
- at com.inductiveautomation.factorypmi.application.model.WindowCache.getWindowInfo(WindowCache.java:151)*
- at com.inductiveautomation.factorypmi.application.model.WindowCache.openWindow(WindowCache.java:397)*
- at com.inductiveautomation.factorypmi.application.VisionDesktop$RuntimeWindowOpener.openWindow(VisionDesktop.java:479)*
- at com.inductiveautomation.factorypmi.application.VisionDesktop.openWindow(VisionDesktop.java:195)*
- at com.inductiveautomation.factorypmi.application.VisionDesktop.openWindow(VisionDesktop.java:187)*
- at com.inductiveautomation.factorypmi.application.FPMIApp.startup(FPMIApp.java:515)*
- at com.inductiveautomation.factorypmi.application.runtime.ClientPanel$13$1.run(ClientPanel.java:751)*
- at java.awt.event.InvocationEvent.dispatch(Unknown Source)*
- at java.awt.EventQueue.dispatchEventImpl(Unknown Source)*
- at java.awt.EventQueue.access$500(Unknown Source)*
- at java.awt.EventQueue$3.run(Unknown Source)*
- at java.security.AccessController.doPrivileged(Native Method)*
- at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)*
- at java.awt.EventQueue.dispatchEvent(Unknown Source)*
- at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)*
- at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)*
- at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)*
- at java.awt.EventDispatchThread.pumpEvents(Unknown Source)*
- at java.awt.EventDispatchThread.run(Unknown Source)*
I am on v. 7.9.10.
Does anyone have some hints on what I am missing?
Regards Stian Larsen
