Hello
good afternoon
I have a question.
how do I open a window when an alarm is activated?
regards
This example uses any unacknowledged alarm…
Create DB Tag to count number of unacknowledged alarms:
Client script to open window if more than zero alarms exist:
If you are looking for just just one alarm, you can use the AlertActive property of the SQLTag you are using in a Client Change Tag script:
Good morning Jordan
I did as you suggested but I did not work I’ll be doing something wrong.
is there another way to do it.
what I want is that when an alarm to open a screen, with each alarm is a different screen.
can you help me with this.
regards
Is the [1] you have in your script the SQLTag provider name?
Also, Client scripts do not run in the Designer. Be sure the project is saved and run the project as a Client.
