Opening an MS Access file and a macro
Hi all, I'm trying to open an MS Access macro in Ignition. I've used the script console but no luck getting it to open even the file.
system.util.execute(['C:\\Users\\Ignition\\Ignition.mdb'])
This is the error:
Java Traceback:
  File "<input>", line 1, in <module>
	at java.base/java.lang.ProcessBuilder.start(Unknown Source)
	at java.base/java.lang.Runtime.exec(Unknown Source)
	at com.inductiveautomation.ignition.common.script.builtin.SystemUtilities.execute(SystemUtilities.java:146)
java.io.IOException: java.io.IOException: Cannot run program "C:\Users\Ignition\Ignition.accdb": CreateProcess error=2, The system cannot find the file specified
	at org.python.core.Py.JavaError(Py.java:547)
	at org.python.core.Py.JavaError(Py.java:538)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:192)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:553)
	at org.python.core.PyObject.__call__(PyObject.java:461)
	at org.python.core.PyObject.__call__(PyObject.java:465)
	at org.python.pycode._pyx49.f$0(<input>:1)
	at org.python.pycode._pyx49.call_function(<input>)
	at org.python.core.PyTableCode.call(PyTableCode.java:173)
	at org.python.core.Py.runCode(Py.java:1687)
	at org.python.core.Py.exec(Py.java:1731)
	at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:277)
	at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:130)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:628)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:616)
	at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
	at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.io.IOException: Cannot run program "C:\Users\Ignition\Ignition.accdb": CreateProcess error=2, The system cannot find the file specified
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
	... 19 more
Caused by: java.io.IOException: CreateProcess error=2, The system cannot find the file specified
	at java.base/java.lang.ProcessImpl.create(Native Method)
	at java.base/java.lang.ProcessImpl.<init>(Unknown Source)
	at java.base/java.lang.ProcessImpl.start(Unknown Source)
	... 29 more
Java Traceback:
java.io.IOException: java.io.IOException: Cannot run program "C:\Users\Ignition\Ignition.mdb": CreateProcess error=32, The process cannot access the file because it is being used by another process
	at org.python.pycode._pyx51.f$0(<input>:1)
	at org.python.pycode._pyx51.call_function(<input>)
Caused by: java.io.IOException: Cannot run program "C:\Users\Ignition\Ignition.mdb": CreateProcess error=32, The process cannot access the file because it is being used by another process
	... 19 more
Caused by: java.io.IOException: CreateProcess error=32, The process cannot access the file because it is being used by another process
	... 29 more
Any advice?
Something like this, though it will depend on what version of office you have installed:
system.util.execute(['C:\\Program Files\\Microsoft Office\\root\\Office16\MSACCESS.EXE', 'C:\\Users\\Ignition\\Ignition.mdb'])
And also only work in a Vision client. Perspective clients cannot run anything local to the user.
I would probably use start, to lean on the OS and not require an explicit path to an executable:
system.util.execute(["start", "", "C:\\Users\\Ignition\\Ignition.mdb"])
https://ss64.com/nt/start.html
The empty string is the value you must supply for the 'title' of the launched process, apparently.
This doesn't seems to work for me.
Anyway, above code @josborn showed worked.
Thank you all.
It didn't like start by itself, only way I got it to run was
system.util.execute(["cmd.exe", "/c", "start \"\" \"Path\\To\\File\""])
or alternatively
system.util.execute(["cmd", "/c", "start", '""', "Path\\To\\File"])
Also worked using subprocess.call() with shell=True, for probably the same reasons.
One more question: How do I close the file that i open? Is there a command when i import os?
I tried using
import os
os.remove('C:\\Users\\Ignition\\Ignition.mdb')
But it completely deleted my file.
I haven't used this but i think os.close() would do it.
What do you mean by 'close'?
system.util.execute is launching a process. That's it. What that process does with any arguments passed into it is up to that process.
system.util.execute also does not return a process ID or handle or anything. If you want to kill the launched process, you'll have to discover it yourself, or use a different mechanism to launch it (i.e. search on this forum for usage examples of Java's ProcessBuilder).
So pretty much I'm calling a DLL API in Access. I've written some VBA code to handle the API in Access side. When i open the Access file, it runs the VBA and after that i want to close the Access file. If i keep it open, every time i call the Access file from Ignition, it'll just open another instance.
I guess I'll try looking in Java's ProcessBuilder.
Could you just close it on the access side with DoCmd.Quit method (Access) | Microsoft Learn
Perfect. This works like a charm. I've added into VBA QuitAccess command.
Thank you all.
