I am just started to have a problem opening designer when I can click the link from the Ignition Gateway it IE ask me to open or save when I select open it opens an XML file in IE. This started happening after unintalling a 64 Bit version of ignition and installing the 32 bit version on a windows 64 bit 2008 server so that I can used the OPCCom class. I did uninstalled java 32 bit and installed java 32 bit.
Any ideas.
