Hello is it possible to launch my ignition project on a web broswer, that is not the system i used to creat the project. I am using the free trial
Yes this is possible, as long as the system that has the Gateway installed and running is reachable by this web browser, and the trial is reset.
Okay thank you, I have tried it severally but dosent work. Also tried going to project
Are you able to connect to the gateway from your client PC? Use the gateway's IP address and port 8088. e.g., 192.168.123.100:8088.
If you succeed then go to down to Perspective Session Launcher and click the View Projects button.
If you don't succeed then check that your client can ping the gateway.
hello, Yes i am able to connect to the client PC. but cant ping the gateway. Is there anyother way to go about it ?
Yes i am able to connect to the client PC....
You should be on the client PC when running the test and pinging the gateway, not trying to connect to the client PC.
... but cant ping the gateway.
If you can't ping the gateway it may be because ping is disabled somewhere along the routing chain but more likely that you don't have access to that IP address. Get the IT guys to give you some help.
