I would like to be able to open some pages using a drop down menu, created a drop down and in data set viewer, added the name of the pages and gave them a value, now I assume I need to use scripting under drop down component scripting? something like:
Add an additional column named “Path” to the dropdown’s dataset. This will hold the path to the window.
Then add the following to the dropdown propertyChange
if event.propertyName == "selectedIndex":
if event.newValue != -1:
data = event.source.data
path = data.getValueAt(event.newValue,"Path")
system.nav.openWindow(path)
