Openpyxl & Ignition
Hello folks
So I’m looking at a project that needs to insert data in to a worksheet in an excel workbook, about 200 cells. this will happen once a week and the worksheet changes very week.
I’d like to do this within Ignition using a script. I found the openpyxl python library and this seems to fit the bill, however the latest versions only support Python down to 2.6 not 2.5 that Ignition uses. I found version 1.7 (the latest to support python 2.5) and it works fine except it will not maintain the spreadsheet conditional formatting that I need. If I try to use a newer openpyxl version then I get errors in the first few lines of library as it loads.
I don’t really know how big the changes between python 2.5 and 2.6 are, is it worth me trying to modify openpyxl to work with 2.5 (feels like a massive job) or do we know if 2.6 or higher will be implemented in Ignition 7.8?
Is there a better way?
We won’t be able to upgrade Jython from 2.5 to 2.7 for Ignition 7.8 because it requires Java 7 at a minimum.
Trying to fork and modify openpyxl to be 2.5 seems like a big undertaking to me… I’d just look for another library.
Kevin
Thanks for the reply, I guessed as much from previous posts, still worth asking, as to using another library; which one?
I’ve looked at using pywin32 but I can’t figure out how to install it as a library, it seems to be only available as a self installing file.
What about leveraging a Java library?
https://poi.apache.org/
I have a completed Ignition module that exposes Apache POI to Python scripting. I am just waiting for the module to be released on Module Marketplace. Hopefully it will be there sometime today.
Thanks for the info guys,
java was my next stop but I have found openpyxl’s little brother https://bitbucket.org/amorris/editpyxl/overviewl. it does exactly what I need (apparently)
this still needs python 2.6 but is only 28k so i might just be able to fork it back to 2.5.
I will take a look at Apache POI
We have a module on the market place that exposes the POI library already. Been there for over a year. I’ll find the link when I get home.
Hi Kyle,
I didn’t realize that. Before I made an Office Document module I downloaded the documentation for the Kymera Office Document Module and read the documentation. The documentation lists functions for creating a new excel document and adding datasets to it. But Apache POI can do much much more than that. I just now downloaded the module and looked inside and I see Apache POI in it. So once that module is installed Python should be able to access all of Apache POI.
Here’s a link to the Kymera Office Document Module: marketplace.inductiveautomation. … oduleId=73
Best,
Kyle
One of the first things I did was look at your module but the manual seemed to indicate that it could only produce Excel files from datasets and save them etc, not update cell values from existing and without disturbing the rest of the file.
I’ll take a look, do you have anymore documentation?
To get a workbook, you can call either system.poi.file.openWorkbook(String filepath) or system.poi.file.openDBWorkbook(byte[])(I think).
From there, you can use the POI API to work with the work book. When you are done, you call system.poi.file.saveWorkbook(file,workbook)(Again, I think). I’ll get one of our devs to update this thread. Enclosed is a working example of importing from a XLS file.
from org.apache.poi.ss.usermodel import Row,Cell
path = system.file.openFile("xlsx")
columns = ["cimplicity_tag_path","tag_path","display_name"]
if path:
	wb = system.poi.file.openWorkbook(path)
	sheet = wb.getSheet("Sheet1")
	for row in sheet:
		values = {}
		for cn in range(3):
			cell = row.getCell(cn,Row.RETURN_BLANK_AS_NULL)
			if cell is None:
				print "blank!!!!"
			else:
				if cell.getCellType() == Cell.CELL_TYPE_STRING:
					values[columns[cn]] = cell.getRichStringCellValue().getString()
				elif cell.getCellType() == Cell.CELL_TYPE_NUMERIC:
					if system.poi.utils.DateUtil.isCellDateFormatted(cell):
						values[columns[cn]] = cell.getDateCellValue()
					else:
						values[columns[cn]] =  cell.getNumericCellValue()
				elif cell.getCellType() == Cell.CELL_TYPE_BOOLEAN:
					values[columns[cn]] = cell.getBooleanCellValue()
				elif cell.getCellType() == Cell.CELL_TYPE_FORMULA:
					values[columns[cn]] = cell.getCellFormula()
		system.db.runSFPrepUpdate("INSERT INTO tags (`cimplicity_tag_path`,`tag_path`,`display_name`,`definition`) VALUES (?,?,?,'{}')",values.values(),["ignition"])
Hi Kyle I get following error when i do this:
File “event:actionPerformed”, line 5, in
AttributeError: ‘com.inductiveautomation.ignition.common.script.Imm’ object has no attribute ‘poi’
Ignition v7.9.5 (b2017111615)
Java: Oracle Corporation 1.8.0_171"
Also is there a way to export table data to existing excel file format?
Did you install the referenced Kymera add-on module?
java.lang.IllegalAccessError: java.lang.IllegalAccessError: tried to access method org.apache.poi.util.POILogger.log(ILjava/lang/Object;)V from class org.apache.poi.openxml4j.opc.PackageRelationshipCollection
caused by IllegalAccessError: tried to access method org.apache.poi.util.POILogger.log(ILjava/lang/Object;)V from class org.apache.poi.openxml4j.opc.PackageRelationshipCollection
I did install I get error as above? I have trial version do I need full version to test this?
What scope are you running this from? There should be no conflicts in the client or designer.
