Operation with 2 parameters in a single table
Good morning everyone,
I am trying to do a calculation of two parameters in the report section, but I think I am missing something in the syntax so that these two values give me a result, in this case a multiplication.
what I am using
@date_now@*@constant@
result
How can I perform this calculation?
regards
The @ sign is a special symbol used only in the reporting module. An expression inside two of these symbols is called a key chain expression (not related to Ignition's Expression language).
You can find more info about key chain expressions here:
And a link to the docs for the software that the reporting module was built on can be found here:
https://www.reportmill.com/support/DesDocs.html
The answer to your question (assuming date_now has a data type that supports multiplication) is this:
@date_now*constant@
its works! @date_now*constant@
thanks Brandon
