Hello
I need to test two dates.
I have placed a button with a very simple script that I copy below:
date1 = system.date.getDate(system.tag.read("[Client]StartYY").value, system.tag.read("[Client]StartMM").value-1, system.tag.read("[Client]StartDD").value)
date2 = system.date.getDate(system.tag.read("[Client]StopYY").value, system.tag.read("[Client]StopMM").value-1, system.tag.read("[Client]StopDD").value)
print date1
print date2
if system.date.dateIsAfter(date2, date1):
print “ok”
else:
print “ko”
When I press the button I obtain this error:
File “event:mouseReleased”, line 8, in
AttributeError: ‘com.inductiveautomation.ignition.common.script.Imm’ object has no attribute ‘dateIsAfter’
at org.python.core.Py.AttributeError(Py.java:173)
at org.python.core.PyObject.noAttributeError(PyObject.java:930)
at org.python.core.PyObject.__getattr__(PyObject.java:925)
at org.python.pycode._pyx10.f$0(<event:mouseReleased>:11)
at org.python.pycode._pyx10.call_function(<event:mouseReleased>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:647)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:183)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:284)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at com.sun.proxy.$Proxy33.mouseReleased(Unknown Source)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
Ignition v7.9.1 (b2017012511)
Java: Oracle Corporation 1.8.0_131
I used dateIsAfter according to documentation.
Many thanks
C.
