Hello,
I am having visual issues on my more complicated SVGs when I optimize them. I am wondering what the difference in performance using standard SVGs for certain tasks. I have a very large project so the percentage difference matters more than in a smaller project.
Thanks.
Can you show examples of the issues you are having? And possibly show a full page.
It will make it easier for people to chime in on.
Yes Sorry,
Here is what the SVG looks like ink scape.
And here is what it looks like after I choose optimized SVG and bring it into perspective.
I think there is an issue with the text being stuck a specific size. When I lowered the text size it remained the same as it was previously.
Let me know if I am leaving something out
What happens when you import the unoptimised svg into perspective? Do you see the same result? I suspect you will. It may be that perspective doesn't support (yet?) the SVG features you're using, although I know there was work done in recent versions to improve this. What version are you on?
I actually just figured out the issue! The Converting CSS attributes to XML attributes was for some reason messing with the text size.
But I also have a similar question which you will also see in the examples. I have curved corners in my Inkscape drawing but when importing they are back to sharp (even as a normal SVG). I know I can maybe take a circle and create the same effect but I am wondering, if like you, said perspective does not support the rounding yet.
How do you round your corners?
Did you manage to fix it? and how?
If you are using path effects (Corners) to round your corners it will not be translated to Ignition.
Try rectangle rounding using ry,rx.
https://inkscape-manuals.readthedocs.io/en/latest/squares-and-rectangles.html
In the menu that pops up after selecting optimized SVG I just unchecked Converting CSS attributes to XML attributes. But now I am still having slight alignment issues.
