Oracle Connection - Tables aren't created
I try to connect project with Oracle database. When I define the connection I don’t get any errors.
I supose that when you create a project, Ignition’s tables are created in database, but instead of this tables aren’t created.
After create a project, database continues being in blank without tables.
What I have to do to create Oracle connection and tables?
I’m using Oracle 10g Express Edition.
Thanks.
In your case you converted the MySQL tables into Oracle by manually creating the tables. You need to wipe out the tables, let Ignition re-create them and import the data.
