Order by problem
When I make a table and under the SQL Query and put in ORDER BY then whatever ASC and hit ok I always get this error.
Exception: Error running query:
SQLQuery(query=SELECT ID, Name, Address, Phone FROM Customers2
WHERE Name LIKE ‘%%’
ORDER BY Name ASC, database=WEDatabase)@0ms
On: Search Test.Root Container.Table.data
caused by GatewayException: The text, ntext, and image data types cannot be compared or sorted, except when using IS NULL or LIKE operator.
caused by SQLServerException: The text, ntext, and image data types cannot be compared or sorted, except when using IS NULL or LIKE operator.
Ignition v7.3.1 (b496)
Java: Sun Microsystems Inc. 1.6.0_29
Not quite sure what to do to fix it.
Sorting on “LIKE”'d fields with wildcards can be finicky with data types depending on the flavor of SQL.
Try this query:
SELECT ID, Name, Address, Phone FROM Customers2 WHERE Name LIKE '%' ORDER BY cast(Name as varchar(500)) ASC
The logic is that % can match null, but you can’t sort null so the interpreter throws an error.
EDIT: You are successfully running Java 6 with the 29 update? How is that working for you?
Which database are you using (MySQL, MS SQL Server)?
It is a MS SQL Server. Your code worked gbuehler thanks!
