Order Tag History by Timestamp Ascending or Descending
Would it be possible to add a “Order By” option to the tag history binding? I like to populate tables with tag history data but I usually want to see the latest entry first. I would be fine with just a Ascending or Descending check box or something like that.
Yes, this definitely seems like something that should be there. We think there are probably a number of things we could do to make querying more flexible, but starting off with this should be easy enough.
I guess for now you could probably rig up a script that runs the query and reverses the dataset, and run the query through that by binding the table dataset to an expression using “runScript”.
Regards,
Is there anything new on this topic?
I would like this too so I submitted the idea to Ignition - up vote if you would like to see this too!
https://inductiveautomation.canny.io/ignition-features-and-ideas/p/tag-history-binding-on-table-advanced-querying
