Machine: Windows 7 , 8 GB RAM, 64 bit
Client Memory on Ignition Properties are : Initial 32M Maximum 512M
When the Project update available is updated on Client this pop up error appears.
java.lang.OutOfMemoryError: Java heap space
at java.util.Arrays.copyOf(Unknown Source)
at java.io.ByteArrayOutputStream.grow(Unknown Source)
at java.io.ByteArrayOutputStream.ensureCapacity(Unknown Source)
at java.io.ByteArrayOutputStream.write(Unknown Source)
at sun.nio.cs.StreamEncoder.writeBytes(Unknown Source)
at sun.nio.cs.StreamEncoder.implWrite(Unknown Source)
at sun.nio.cs.StreamEncoder.write(Unknown Source)
at java.io.OutputStreamWriter.write(Unknown Source)
at java.io.PrintWriter.write(Unknown Source)
at java.io.PrintWriter.print(Unknown Source)
at com.inductiveautomation.ignition.common.project.Project.toXML(Project.java:882)
at com.inductiveautomation.ignition.common.project.Project.toXML(Project.java:819)
at com.inductiveautomation.ignition.common.project.Project.toXML(Project.java:809)
at com.inductiveautomation.factorypmi.application.runtime.UpdateProjectPane$ApplyDiff.run(UpdateProjectPane.java:155)
at com.inductiveautomation.ignition.client.launch.AbstractStepRunner.run(AbstractStepRunner.java:32)
at java.lang.Thread.run(Unknown Source)
