I’m getting the following error occasionally …INFO | jvm 1 | 2012/05/01 10:23:31 | SEVERE: Servlet.service() for servlet default threw exception
INFO | jvm 1 | 2012/05/01 10:23:31 | java.lang.OutOfMemoryError: PermGen space
INFO | jvm 1 | 2012/05/01 10:23:31 | at java.lang.Class.getDeclaredConstructors0(Native Method)
INFO | jvm 1 | 2012/05/01 10:23:31 | at java.lang.Class.privateGetDeclaredConstructors(Class.java:2404)
INFO | jvm 1 | 2012/05/01 10:23:31 | at java.lang.Class.getConstructor0(Class.java:2714)
INFO | jvm 1 | 2012/05/01 10:23:31 | at java.lang.Class.newInstance0(Class.java:343)
INFO | jvm 1 | 2012/05/01 10:23:31 | at java.lang.Class.newInstance(Class.java:325)
INFO | jvm 1 | 2012/05/01 10:23:31 | at sun.reflect.MethodAccessorGenerator$1.run(MethodAccessorGenerator.java:399)
INFO | jvm 1 | 2012/05/01 10:23:31 | at sun.reflect.MethodAccessorGenerator$1.run(MethodAccessorGenerator.java:396)
INFO | jvm 1 | 2012/05/01 10:23:31 | at java.security.AccessController.doPrivileged(Native Method)
INFO | jvm 1 | 2012/05/01 10:23:31 | at sun.reflect.MethodAccessorGenerator.generate(MethodAccessorGenerator.java:395)
INFO | jvm 1 | 2012/05/01 10:23:31 | at sun.reflect.MethodAccessorGenerator.generateSerializationConstructor(MethodAccessorGenerator.java:113)
INFO | jvm 1 | 2012/05/01 10:23:31 | at sun.reflect.ReflectionFactory.newConstructorForSerialization(ReflectionFactory.java:331)
INFO | jvm 1 | 2012/05/01 10:23:31 | at java.io.ObjectStreamClass.getSerializableConstructor(ObjectStreamClass.java:1356)
INFO | jvm 1 | 2012/05/01 10:23:31 | at java.io.ObjectStreamClass.access$1500(ObjectStreamClass.java:69)
INFO | jvm 1 | 2012/05/01 10:23:31 | at java.io.ObjectStreamClass$2.run(ObjectStreamClass.java:480)
INFO | jvm 1 | 2012/05/01 10:23:31 | at java.io.ObjectStreamClass$2.run(ObjectStreamClass.java:455)
INFO | jvm 1 | 2012/05/01 10:23:31 | at java.io.ObjectStreamClass.<init>(ObjectStreamClass.java:455)
INFO | jvm 1 | 2012/05/01 10:23:31 | at java.io.ObjectStreamClass.lookup(ObjectStreamClass.java:352)
INFO | jvm 1 | 2012/05/01 10:23:31 | at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1130)
INFO | jvm 1 | 2012/05/01 10:23:31 | at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.java:346)
INFO | jvm 1 | 2012/05/01 10:23:31 | at org.apache.wicket.util.io.IObjectStreamFactory$DefaultObjectStreamFactory$2.writeObjectOverride(IObjectStreamFactory.java:121)
INFO | jvm 1 | 2012/05/01 10:23:31 | at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.java:342)
INFO | jvm 1 | 2012/05/01 10:23:31 | at org.apache.wicket.util.lang.Objects.objectToByteArray(Objects.java:1120)
INFO | jvm 1 | 2012/05/01 10:23:31 | at org.apache.wicket.protocol.http.pagestore.AbstractPageStore.serializePage(AbstractPageStore.java:203)
INFO | jvm 1 | 2012/05/01 10:23:31 | at org.apache.wicket.protocol.http.pagestore.DiskPageStore.storePage(DiskPageStore.java:840)
INFO | jvm 1 | 2012/05/01 10:23:31 | at org.apache.wicket.protocol.http.SecondLevelCacheSessionStore$SecondLevelCachePageMap.put(SecondLevelCacheSessionStore.java:332)
INFO | jvm 1 | 2012/05/01 10:23:31 | at org.apache.wicket.Session.requestDetached(Session.java:1404)
INFO | jvm 1 | 2012/05/01 10:23:31 | at org.apache.wicket.RequestCycle.detach(RequestCycle.java:1176)
INFO | jvm 1 | 2012/05/01 10:23:31 | at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1454)
INFO | jvm 1 | 2012/05/01 10:23:31 | at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
INFO | jvm 1 | 2012/05/01 10:23:31 | at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:479)
INFO | jvm 1 | 2012/05/01 10:23:31 | at org.apache.wicket.protocol.http.WicketFilter.doFilter(WicketFilter.java:312)
INFO | jvm 1 | 2012/05/01 10:23:31 | INFO [ModuleManager ] [10:23:31,842]: Starting up module "potayto-potahto-site-designerclient"...
INFO | jvm 1 | 2012/05/01 10:23:54 | May 01, 2012 10:23:53 AM org.apache.catalina.core.StandardWrapperValve invoke
INFO | jvm 1 | 2012/05/01 10:23:54 | SEVERE: Servlet.service() for servlet Map threw exception
INFO | jvm 1 | 2012/05/01 10:23:54 | java.lang.OutOfMemoryError: PermGen space… thinking that perhaps there’s something Wicket related I’m not taking into consideration? I’ve got a Homepage Panel setup, (refer to this thread).
Thanks!
