Looking to convert bit value as a string. For example, an output of 1 would get converted to a string “Fail”, 0 would be “Normal”
You can use the case command in an expression binding
case({PathToYourBit},0,'GOOD',1,'FAIL','UNKNOWN')
Perfect thanks for the information!!
