if anybody know about this.
I'm not sure why you would want to customize those, as they exist to indicate a potential problem, and are not something you would want the end user to ever see. You can suppress them using "Overlay Opt-out" if you know that the cause is not an issue of concern.
This UI piece is not directly exposed within the Designer. As with everything else, you can apply your own styling to this piece with settings applied within the Gateway-wide theming files, or project specific stylesheet.css resource.
I usually throw something like this in my theme to make those errors not as intrusive by only keeping the dot and adding a transition delay. Makes the UI a lot cleaner IMO.
.ia_qualityOverlay__icon--error {
visibility: hidden;
animation: iaOutlineShow 0s linear forwards;
animation-delay: 2s;
.micro-icon-container {
visibility: hidden;
@keyframes iaOutlineShow {
to {
visibility: visible;
.ia_qualityOverlay--error{
border-color: #00000000 !important;
.ia_qualityOverlay__footer--error {
background-color: #00000000;
color: #00000000;
