Override a UDT Script?
Is it possible to override the script attached to a tag that's part of a UDT? We have a UDT that's attached to a couple of hundred tags but we have one tag instance that we want to function a bit differently than the others. I thought that, once upon a time, it was a matter of checking or unchecking a box but I'm not seeing any way to do it now.
Thanks in advance!
Click the little circle, it turns green when overrode.
So simple and so not very obvious. Thanks!
You don't even have to click it--it should change to overridden when you edit that instance's script.
Not for me, it's greyed out until overridden.
Huh. I wonder when that changed. (Or maybe I misremembered. I might be getting old. :roll_eyes: )
The gray script box is what I was seeing too. Thanks for all of your help everyone!
