Hello,
I created 2 UDTs, one inherited (UDT2) from the other (UDT1). In UDT1, I have an expression tag without the expression defined. It needs to be defined in the inherited UDTs. In UDT2, I override the expression.
My question is why when I create instances of UDT2, the expression is shown as overridden? I would expect the instance to not be overridden since it is the same expression as UDT2. Is this a bug or am I misunderdansting something?
I can manually “unoverride” the expression and it keeps the expression defined in UDT2.
The instance is from UDT2, so the instance does not override the UDT2 expression. It is UDT2 which override UDT1. I see a difference here, I don’t know if you see what I understand.
But the UDT2 instance does not override the UDT2 template, do you see what I mean? Anyway I just wanted to see if I was the only one thinking that way.
