Hello to everyone!
I want to alter a dts default value of and UDT struct.. I use the following code to achieve this:
dts = [10Rx2C]
system.tag.write("[x_provider]Visu_Utenze/AG1F1/Command/Config", dts)
This works correctly if i use the [default] standard provider:
But if i use something different from the default one ([Appoggio] in my case) it doesn't write correctly it:
It's like if the tags doesn't store the altered value inside it's memory.. But only "at fly" (temporary). In fact if i reboot the Ignition Gateway the tag return to it's original default UDT's value (if i read the value after the modify, it has the new values).
My questions are:
- Why the same script doesn't work if i use different providers? (NB: Even if i always specify it inside tag path too)
- Why does it behave so?
PS: I use Ignition version: 7.9.14
Thanks!
