This is probably a dumb question but Ive been struggling with it for days…
what would be the best way to overwrite only certian numbers in an Int2 tag?
for example if my PLC has a holding registers whos value is “1234” and I want to overwrite just the first two digits --> I want a numeric text field where I can enter “56” that would change the holding register from “1234” to “5634”
I seem to be unable to use any left or right string commands to write to my Int tag.
I tried creating 2 memory tags mapped to numeric text fields. then I created an Int2 expression tag with “concat({[~]New Tag},{[~]New Tag 1})” and wrote its value back to the OPC tag for my holding register… this seems to work but is extremely slow and this doesnt seem like the way it should be done.
Is there a good way to accomplish this?
Thank you in advance.
Chris
