I have a label which is anchored at the center, with center alignment. I want to fill it with text like:
Left<------------->Right
Where “<------------>” represents multiple spaces. The trouble is that “something” is replacing all the multiple spaces with a single space (and even happened in this forum post)
So what magic do I need to insert into my label text in order to create spaces that don’t disappear?
I tried using multiple , but all that did was print out multiple times
What you are attempting may be a bad idea. It may not scale well if the user has different font settings, etc. Instead you should use two labels - one left justified and one right justified.
