Hi, I have a global docked view and i want to dynamically display the active page title. This can be set in the Perspective window but i can not find the parameter when binding the label in the docked view. Surely there must be a global tag for this and not have to pass parameters around with custom tags.
Hi ,thanks but I have a cloud instance of Ignition and the page.props.title brings up the Ignition instance/project name not the active page title. I should have named the pages "Plant_1" and "Plant_2" to not confuse the Ignition project.
I believe you can change the project title from the gateway - Config->Projects->your_project->Edit or something like that?
Edit the Title, not the project Name!
You can also write to that property directly instead of using custom tags.
