So my conveyor belt canvas works good when I give it a positive angle but whenever I give it a negative angle to run by it won’t translate left to accommodate for the shift in positioning so it just gets cut off. I’m not sure if this is a bug in the system or an error in my code. I can’t seem to locate the error as everything makes sense logically as far as I can tell.
Also the calculations like angleCalc only need to be called when I change the template instance size so is there a way to store the values somehow so it only goes through the calculation the first time the client/page is opened and not when the color changes? Do custom methods already do this?
Repaint:
from java.lang import Math
from java.awt import Color
from java.awt import GradientPaint
from java.awt.geom import GeneralPath
from java.awt.geom import Rectangle2D
from java.awt.geom import Ellipse2D
g = event.graphics
Code Location
Event Properties
Width and Height Operator
Initial Values
Operators
Back Color Conditional
Indicator Color conditional
Indicator Positions conditional
Components
Background
Indicators
Edges
End Caps
Direction
Rotation and Translation
Paint Shapes
Paint Back and Indicators
Paint Edges and Direction Triangle
Paint end caps conditional
#### Event Properties
#width = event.source.width
#height = event.source.height
Available = event.source.Available
Fault = event.source.Fault
FwdMOn = event.source.FwdMOn
RevMOn = event.source.RevMOn
MJog = event.source.MJog
MOff = event.source.MOff
On = event.source.On
Lcap = event.source.Lcap
Rcap = event.source.Rcap
angle = event.source.angleDegrees
left = event.source.Left
checkHeight = event.source.checkHeight
## Width and Height Operator
angleCalc = event.source.angleCalc(angle, event.source.width)
width = angleCalc[1]
#### Initial Values
if angle != 0:
backColor = Color(255, 255, 255)
indicatorColor = Color(153, 153, 153)
indLx = 0
indRx = width-10
#### Operators
## Back Color conditional
if Available == 0:
backColor = Color(102, 102, 102)
elif Fault == 1:
backColor = Color(250, 50, 50)
elif On == 1:
backColor = Color(153, 153, 153)
## Indicator Color conditional
if Available == 0 and Fault ==1:
indicatorColor = Color(250, 50, 50)
elif MJog == 1:
indicatorColor = Color(255, 150, 0)
elif MOff == 1 or FwdMOn == 1 or RevMOn == 1:
indicatorColor = Color(255, 245, 70)
## Indicator Positions conditional
if Lcap == 1:
indLx = 4
if Rcap == 1:
indRx = width-14
#### Components
## Background
back = Rectangle2D.Float(7,4, width-14,16)
## Indicators
indicatorL = event.source.Indicator(indLx)
indicatorR = event.source.Indicator(indRx)
## Edges
edgeT = event.source.Edge(0, width)
edgeB = event.source.Edge(16,width)
## End Caps
endL = event.source.EndCap(0)
endR = event.source.EndCap(width-4)
## Direction
direction = event.source.Direction(width, left)
#### Rotation and Translation
if angle != 0:
g.translate(angleCalc[2], 0)
g.rotate(Math.toRadians(angle), angleCalc[3], 0)
#### Paint Shapes
## Paint Back and Indicators
g.setColor(backColor)
g.fill(back)
g.setColor(indicatorColor)
g.fill(indicatorL)
g.fill(indicatorR)
## Paint Edges and Direction Triangle
g.setColor(Color(0, 0, 0))
g.fill(edgeT)
g.fill(edgeB)
g.fill(direction)
## Paint end caps conditional
if Lcap == 1:
g.fill(endL)
if Rcap == 1:
g.fill(endR)
## Draw Recommended Height Conditional
if checkHeight == 1:
g.drawString(str(Math.round(angleCalc[0])), event.source.width/2, 35)
angleCalc:
def angleCalc(self, angle, width):
Arguments:
self: A reference to the component instance this method is invoked on. This argument
is automatic and should not be specified when invoking this method.
angle: The angle that this operation will be running from.
width: The width of the canvas.
if angle == 0:
Width = width
height = 20
translateX = 0
pivotX = 0
elif 45 >= angle > 0:
rad = Math.toRadians(angle)
sin = Math.sin(rad)
cos = Math.cos(rad)
tan = Math.tan(rad)
Width = int(width/cos) - int(tan*20)
height = int((tan*width)+(cos*20))
translateX = int(sin*20)
pivotX = 0
elif -45 <= angle < 0:
rad = Math.toRadians(Math.abs(angle))
sin = Math.sin(rad)
cos = Math.cos(rad)
tan = Math.tan(rad)
height = int((tan*width) + (cos*20))
translateX = -int(sin*20)
pivotX = width
return [height, Width, translateX, pivotX]
