Panelview Plus 7 Performance
Running into an issue with ViewPointe that I was unaware of when purchasing the panelview....the idea behind getting this panel was to be able to use the web server(viewpointe) via embedding into ignition. Upon creating a ignition screen I realized only one person can view the HMI at a time, due to licensing, which defeats the purpose when 15+ people will need access.
I realize that an SE application is what is needed, however, the runtime for the panelview is a Machine Edition program. I found a tech note explaining how to convert ME to SE but it doesnt look very promising and im not sure thats the route I want to go. I also found a tech note stating that the PV+ 7 Performance Series B cant even run a SE application?
Has anyone else had a similar experience and found a workaround? Trying to figure out the best route to go here. Thank you.
Throw it away? Sell it on Ebay? (With disclosure that it is a piece of junk, naturally.)
Then implement your application entirely with Perspective. Or perhaps with a Vision client thrown in for the few things Perspective doesn't do well.
( Not really joking. )
