I’m trying to pass parameters a project in applet mode, I’m using the code of a previuos posts:
from javax.swing import JApplet
from javax.swing import SwingUtilities
applet = SwingUtilities.getAncestorOfClass(JApplet, event.source)
value=applet.getParameter(“paramName”)
and I get the instance of the applet without problems but when I try to get the parameter I have None.
I try to use the function applet.getParameterInfo() to check that I have parameters and I’m getting None too.
I’m using Ignition version 7.6.4.
Any suggestions?
