Parsing date throws an exception
Hello!
I’m having troubles parsing dates in Ignition scripting.
When I execute the following code:
print(system.date.now())
The output is:
Wed Jun 30 06:28:38 BRT 2021
The problem comes when I try to do the reverse operation, parsing this same string as a Date
date=system.date.parse('Wed May 05 08:11:59 BRT 2021')v
Throws
java.text.ParseException: java.text.ParseException: Unparseable date: "Wed May 05 08:11:59 BRT 2021"
What is causing this? Is it because this date is a ZonedDateTime?
Thanks in advance
you should probably add in the second parameter for the format string
system.date.parse(‘Wed May 05 08:11:59 BRT 2021’, ‘E MMM dd HH:mm:ss z yyyy’ )
Yes, I have tried multiple iterations of this parameter:
"EEE MM d kk:mm:ss zzz yyyy"
But nothing seems to be working. Any advice?
I just wrote here above xd
Yeah, it seems like we replied to each other at the same time :slight_smile: . Thank you so much, it worked!
np^^ mark my answer as solution if it did^^
