I've got a master-detail view.
The master loads a resultset from a database.
This resultset is used to generate the instances property of a FlexRepeater that repeats a subview for each row.
In a first implementation I passed to the subview the key of that row; the view used that key to issue a query for that single row and get its own resultset that I kept in a custom property of the view and used to populate TextFields values via binding like
getValueAt(0, "FIELDNAME")
This worked but now I would like to explore the possibility of passing directly the row-data from the master, without having each instance of the view, that is each row to reload it's own data.
I bound the instances property of the FlexRepeater to a field with my record primary key (invoice's id) and I used the following binding script:
instances = []
for r in system.db.runPrepQuery("SELECT * FROM INVOICEROWS WHERE INVOICEID=?", [value]):
print str(type(r))
instances.append({"row": r})
return instances
My view obviously has a row parameter that should hold a representation of my row data.
Here I noticed that the type of r is PyRow.
If i check the type on the view side, that is the type of row parameter I see: JsonifiableArrayList.
The problem here is that in this process the column names get lost, so then I can only access values by index and not by column name anymore, and this is something that I would like to avoid.
(I've read somewhere that when python types are saved to properties they get 'stringified', I don't know if this is the case since I don't actally get a string but still a list.).
Finally I decided to ask here not only for finding help on this specific issue but also to get a feedback on how master-detail forms can be designed in perspective, perhaps there is a better way or a best practice that is different from this implementation of mine.
