Pass Report Parameter into Image Key
IGNITION: v8.1.0 Vision - Reporting Module
We have a report image that needs to change when the Customer changes.
The image files (as files) are located on the Gateway. …typically: png, svg and jpg.
The report parameter @CustomerFilespec@ is configured as a String and is the value of ImageShape ( Key Property ).
In the properties…
ImageShape ( Key Property) = CustomerFilespec
(also tried)
ImageShape ( Key Property ) = @CustomerFilespec@
The documentation refers to a Key Browser, but doesn’t indicate the format of the key field when passed as a parameter.
What is the format of the key field, from a parameter standpoint?
We’ve tried the @CustomerFilespec@ parameter values:
“D:/Logo/CustomerA.png”
“file:///D/Logo/CustomerA.png”
“D:\Logo\CustomerA.png”
…the above values seem to make the parser happy, but the image is not displayed.
Debug: TextShape (Text Property ) = @CustomerFilespec@
Results: As expected, per the @CustomerFilespec@ input value above, without the double quotes.
Also, we’ve tried hard coding the paths to the key…same result.
Also 2, I’ve tried jpg and svg…same result.
Basically, we need a way of dynamically sourcing the image to the report, feeding in additional report parameters and saving the report as a pdf, from a script.
Thoughts?
The key parameter needs to contain the image bytes, not a path.
You could use the path in a script to get the image and convert it to bytes and store it as a new data key you can use as the key parameter.
As a side note, I’ve noticed the ImageShape can render pdf bytes as well. With much better results!
@Claus_Nielsen
Thanks for the insight.
