Passing Active Directory credentials to other Perspective projects
Hello,
I am currently trying to set up Active Directory authentication between Ignition Perspective projects, meaning you sign into one project, and the initial sign in passes authentication through all projects on a Gateway.
I have the Active Directory authentication set up in the main project and it seems to be working just fine. I have a script on the startup event to pull all projects and their respective URLs from the gateway via a GET HTTP request, which then formats this information into a flex repeater view. For every project/URL it makes a new instance in the flex repeater view with that information, and a button that calls system.perspective.navigate to navigate to that view.
I need to somehow capture the initial login and propagate those credentials throughout all projects, preferably in a secure way.
I have tried making a login screen with two text fields and a button, and using system.security.validateUser with the text fields as parameters for username and password, and that successfully authenticates, but I am not sure how to pass it to other projects in a secure way (no plaintext).
Is this possible in a secure manner? I am aware that Perspective provides a login method but I didn't see any way to pass credentials into that, or store them in a variable for use elsewhere.
You cannot do this within Ignition. It must be done with your Identity Provider, typically some form of single-sign-on feature. You cannot may your own login form(s) for Perspective within Ignition.
Got it. I have setup an Identity Provider which also seems to be working fine. I was suspecting that a login screen wasn't possible and a bad idea within Ignition.
Maybe my initial post wasn't clear enough. I want to get rid of the sign in screen that pops up every time you open a different project in the browser, and just log in once with AD credentials.
I did some research before I started and found Active Directory SSO Disabled for 8.1.17 & 7.9.20 – Inductive Automation Help Center . Would this apply to authentication between projects on a gateway? Is there any other way I could do this?
You can't, essentially you have two options:
  1. Use SSO and then when you re-direct to projects it still goes through the authentication process but since you are using SSO, it signs in and then move to the project.
Each has its pros and cons.
