I am trying to call an API that has nested parameters. Do I need to use a Preformatted text Expression structure to implement my parameters within my API call? See attached.
SAP.IM.GoodsMovement (Project Script)
# Project Name: NEI Manufacturing Execution System (MES)
# Author: Aisha M.Shiddat
# Date: 8/27/2024
# Description: Reads Good Movement Header and transfers the new key assignment of the GM_CODE to the relevant transactions in Inventory Management
# Copyright (c) 2024 Charlotte Pipe and Foundry Company
# NOTES: WIP
def Post(ItemName, ItemValue,Structure,UserID):
#Instantiate the SAP API Class and set function to be called
ECC = SAP.SAPClass.CSAP(UserID)
ECC.URL = 'api/SAP/Inventory/GoodsMovement'
ECC.Debug = True
#GoodsMvt Header and GoodsMvt_Code are Mandatory Params
#ECC.AddValue('GOODSMVT_HEADER','PSTNG_DATE')
#ECC.AddValue('GOODSMVT_CODE', 'GM_CODE')
#ECC.AddValue('GOODSMVT_ITEM', GmItem)
#Instantiating the CStructure and CTable Class for complex objects
CS1 = SAP.SAPClass.CStructure('GOODSMVT_HEADER')
CS1.SetValue('PSTNG_DATE',list(ItemName)[1])
CS2 = SAP.SAPClass.CStructure('GOODSMVT_CODE')
CS2.SetValue('GM_CODE',list(ItemValue)[1])
dict_one = {
"MOVE_TYPE":Structure[1]["MOVE_TYPE"],
"ENTRY_QNT": Structure[1]["ENTRY_QNT"],
"ENTRY_UOM":Structure[1]["ENTRY_UOM"],
"PO_NUMBER": Structure[1]["PO_NUMBER"],
"PO_ITEM":Structure[1]["PO_ITEM"],
"MVT_IND":Structure[1]["MVT_IND"]
#table
CS3 = SAP.SAPClass.CTable('GOODSMVT_ITEM')
CS3.SetValue('GOODSMVT_ITEM', dict_one)
ECC.AddItem(CS1)
ECC.AddItem(CS2)
ECC.AddItem(CS3)
PV = ECC.Post()
return PV
Event Configuration on Receive Button
#set variables/ params
PONumber = self.parent.parent.getChild("Scrap_Receiving_Flex_Container").getChild("PO_No_Flex_Container").getChild("PO_No_Value").props.value
grossWeight = self.parent.parent.getChild("Scrap_Receiving_Flex_Container").custom.gross_weight
netWeight = self.parent.parent.getChild("Scrap_Receiving_Flex_Container").custom.net_weight
scaleWeight = self.parent.parent.getChild("Scrap_Receiving_Flex_Container").custom.scale_weight
receiptQty = self.parent.parent.getChild("Scrap_Receiving_Flex_Container").custom.receipt_qty
# ItemName = {TODO}
# ItemValue = {TODO}
# Structure = {TODO}
UserID = self.view.params.userId
if(PONumber is not None):
#call ZBAPI_GOODMVT_CREATE
#create_gm = SAP.IM.GoodsMovement.Post(ItemName, ItemValue, Structure, UserID)
#insert truck weight data into Raw Materials table
sd_params = {"po_number":PONumber, "gross_weight":grossWeight, "net_weight":netWeight, "scale_weight": scaleWeight, "receipt_qty":receiptQty}
system.db.runNamedQuery("SAP/RM_UpdateExitWeight", sd_params)
#Open confirmation view
system.perspective.openPopup('Exit Weight Confirmation', 'Inventory/Scrap_Receive_Confirmation View' )
# Invoke message handler
system.perspective.sendMessage('refreshTable')
#reset fields
self.parent.parent.getChild("Scrap_Receiving_Flex_Container").getChild("PO_No_Flex_Container").getChild("PO_No_Value").props.value = " "
self.parent.parent.getChild("Scrap_Receiving_Flex_Container").getChild("Gross Weight").getChild("FlexContainer_0").getChild("gross_weight_entry").props.value = " "
self.parent.parent.getChild("Scrap_Receiving_Flex_Container").getChild("Scale_Weight_Container").getChild("scale_weight_entry").props.value = " "
self.parent.parent.getChild("Scrap_Receiving_Flex_Container").getChild("Net Weight").getChild("FlexContainer_0").getChild("net_weight_entry").props.value = " "
self.parent.parent.getChild("Scrap_Receiving_Flex_Container").getChild("Receipt Qty").getChild("receipt_qty_entry").props.value = " "
self.parent.parent.parent.getChild("Shipment Detail").getChild("root").getChild("Shipment_Detail_Flex_Container").getChild("PO_No_Flex_Container").getChild("PO_No_Value").props.value = " "
self.parent.parent.parent.getChild("Shipment Detail").getChild("root").getChild("Shipment_Detail_Flex_Container").getChild("BOL_No_Flex_Container").getChild("BOL_No_Value").props.text = " "
self.parent.parent.parent.getChild("Shipment Detail").getChild("root").getChild("Shipment_Detail_Flex_Container").getChild("Scale_Weight_Container").getChild("scale_weight_input").props.text = " "
self.parent.parent.parent.getChild("Scrap_Inspection").getChild("ColumnContainer").getChild("Contamination_Flex_Container").getChild("Cast_Iron_Container").getChild("Cast_Iron_RadioGroup").props.value = None
self.parent.parent.parent.getChild("Scrap_Inspection").getChild("ColumnContainer").getChild("Contamination_Flex_Container").getChild("Enameled_Flex_Container").getChild("Enameled_RadioGroup").props.value = None
self.parent.parent.parent.getChild("Scrap_Inspection").getChild("ColumnContainer").getChild("Contamination_Flex_Container").getChild("Steel_Flex_Container").getChild("Steel_RadioGroup").props.value = None
self.parent.parent.parent.getChild("Scrap_Inspection").getChild("ColumnContainer").getChild("Contamination_Flex_Container").getChild("Non_Ferrous_Flex_Container").getChild("Non_Ferrous_RadioGroup").props.value = None
self.parent.parent.parent.getChild("Scrap_Inspection").getChild("ColumnContainer").getChild("Contamination_Flex_Container").getChild("Non_Metallics_Flex_Container").getChild("Non_Metallics_RadioGroup").props.value = None
self.parent.parent.parent.getChild("Scrap_Inspection").getChild("ColumnContainer").getChild("Contamination_Flex_Container").getChild("Material_Certification_Container").getChild("Material_Certification_RadioGroup").props.value = None
self.parent.parent.parent.getChild("Scrap_Inspection").getChild("ColumnContainer").getChild("Scrap_Ins_Flex_Container").getChild("Size_Flex_Container").getChild("Transporation_Type_Flex_Container").getChild("Transportation_Type_Radio_Button").props.value = None
self.parent.parent.parent.getChild("Scrap_Inspection").getChild("ColumnContainer").getChild("Scrap_Ins_Flex_Container").getChild("Size_Flex_Container").getChild("Larger_24_24_Flex_Container").getChild("Larger_24_24_RadioGroup").props.value = None
self.parent.parent.parent.getChild("Scrap_Inspection").getChild("ColumnContainer").getChild("Scrap_Ins_Flex_Container").getChild("Size_Flex_Container").getChild("Weight_Over200_Flex_Container").getChild("Weight_Over200_RadioGroup").props.value = None
self.parent.parent.parent.getChild("Scrap_Inspection").getChild("ColumnContainer").getChild("Scrap_Ins_Flex_Container").getChild("Size_Flex_Container").getChild("Environmental_Pass").props.selected = False
self.parent.parent.parent.getChild("Scrap_Inspection").getChild("ColumnContainer").getChild("Scrap_Ins_Flex_Container").getChild("Size_Flex_Container").getChild("Inspected_By_Flex_Container").getChild("Inspected_By_Value").props.value = None
self.parent.parent.parent.getChild("Scrap_Inspection").getChild("ColumnContainer").getChild("Scrap_Ins_Flex_Container").getChild("Size_Flex_Container").getChild("Disposition_Flex_Container").getChild("Disposition_Value").props.value = None
self.parent.parent.parent.getChild("Scrap_Inspection").getChild("ColumnContainer").getChild("Scrap_Ins_Flex_Container").getChild("Size_Flex_Container").getChild("Comments_Flex_Container").getChild("Comments_Value").props.text = " "
PostMan Example (Calling API from SAP)
