I know I am missing something simple here…
I have a valve that has a virtual HOA associated with it. There is a valve graphic on my HMI that when you click on it opens a popup with the HOA selector. I am passing in the HOA value as an integer (0= off, 1 = auto, 2= hand) which is tied to a Mult-state button. It is indicator is just fine so I know its not an issue with passing parameters in but for some reason I can’t pass the HOA selection back out of the popup to the tag. I can edit the HOA value in the tag browser so I know the connection to the PLC is fine. I believe my issue lies in some tag is not set to bidirectional but I cannot figure out where its at. The HOA multi-state button is bi-directional, so it should send it right back out of the popup. .
I am wondering if its having issues passing the parameter values back out of the popup as I didn’t set anything special on there except for the “Pass Parameters” box. I know I am missing something dumb but can anyone see a spot where I tripped up.
