Hi. I'm trying to call a method using system.opcua.CallMethod like the following code:
output = system.opcua.callMethod(
"OPC_Pedidos",
"ns=2;s=/Pedidos",
"ns=2;s=/Pedidos/BasicReport",
When I check output[2], I obtain an empty list. However, when I call the method with the following syntax:
"OPC_Pedidos",
"ns=2;i=1",
"ns=2;i=28",
The result is what I expected. In the OPC Browser, my methods are organized like this:
Is there any errors in my syntax on the first code? It would be useful to call the node via a string, because when creating or eliminating methods, the ids change and I need to change the id on the script.
Thanks in advance, Gabriel.
