Passing value from child template to parent template
I created a template with a repeater.
Inside this template will be templated toggle buttons.
I want to notify the parent template with repeater when any of the templated toggle buttons gets selected or deselected.
How can I achieve this?
lol…
toggle button click >
event.source.parent.parent.parent.parent.parent.parent.SomeCustomMethodOnParentTemplate()
print event.source
	print event.source.parent
	print event.source.parent.parent
	print event.source.parent.parent.parent
	print event.source.parent.parent.parent.parent
	print event.source.parent.parent.parent.parent.parent
	print event.source.parent.parent.parent.parent.parent.parent
	print event.source.parent.parent.parent.parent.parent.parent.parent
	print event.source.parent.parent.parent.parent.parent.parent.parent.parent
	print event.source.parent.parent.parent.parent.parent.parent.parent.parent.parent
	print event.source.parent.parent.parent.parent.parent.parent.parent.parent.parent.parent
	print event.source.parent.parent.parent.parent.parent.parent.parent.parent.parent.parent.parent
	print event.source.parent.parent.parent.parent.parent.parent.parent.parent.parent.parent.parent.parent
1:
com.inductiveautomation.factorypmi.application.components.PMIToggleButton[button,0,0,124x85,alignmentX=0.0,alignmentY=0.5,border=,flags=16777512,maximumSize=,minimumSize=,preferredSize=,defaultIcon=,disabledIcon=,disabledSelectedIcon=,margin=javax.swing.plaf.InsetsUIResource[top=3,left=14,bottom=3,right=14],paintBorder=false,paintFocus=true,pressedIcon=,rolloverEnabled=false,rolloverIcon=,rolloverSelectedIcon=,selectedIcon=,text=Job]
2:
ToggleStripButton
3:
com.inductiveautomation.factorypmi.application.components.TemplateRepeater$VerticalView[,0,0,124x346,layout=net.miginfocom.swing.MigLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=16777217,maximumSize=,minimumSize=,preferredSize=]
4:
javax.swing.JViewport[,0,0,124x768,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=25165824,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=true,lastPaintPosition=java.awt.Point[x=0,y=0],scrollUnderway=false]
5:
com.inductiveautomation.factorypmi.application.components.TemplateRepeater$1[,0,0,124x768,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=,flags=16777536,maximumSize=,minimumSize=,preferredSize=,columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,hidden,layout=com.incors.plaf.alloy.AlloyScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=javax.swing.plaf.BorderUIResource$EmptyBorderUIResource@78fa5cad,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,hidden,layout=com.incors.plaf.alloy.AlloyScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=javax.swing.plaf.BorderUIResource$EmptyBorderUIResource@78fa5cad,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,124x768,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=25165824,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=true,lastPaintPosition=java.awt.Point[x=0,y=0],scrollUnderway=false],viewportBorder=]
6:
com.inductiveautomation.factorypmi.application.components.TemplateRepeater[repeater,0,0,124x768,layout=com.inductiveautomation.ignition.client.util.gui.FillingLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=9,maximumSize=,minimumSize=,preferredSize=]
7:
ToggleStrip
8:
com.inductiveautomation.factorypmi.application.components.template.TemplateHolder[ToggleStrip,0,0,124x768,layout=com.inductiveautomation.factorypmi.application.components.template.TemplateHolder$1,alignmentX=0.0,alignmentY=0.0,border=,flags=16777217,maximumSize=,minimumSize=,preferredSize=]
9:
Root Container
10:
javax.swing.JLayeredPane[null.layeredPane,0,0,124x768,alignmentX=0.0,alignmentY=0.0,border=,flags=0,maximumSize=,minimumSize=,preferredSize=,optimizedDrawingPossible=true]
11:
javax.swing.JRootPane[,0,0,124x768,layout=com.incors.plaf.alloy.bk,alignmentX=0.0,alignmentY=0.0,border=,flags=449,maximumSize=,minimumSize=,preferredSize=]
12:
LeftNavigation
13:
com.inductiveautomation.ignition.designer.designable.DesignPanel$DesignableContainerLayer[,0,0,749x783,alignmentX=0.0,alignmentY=0.0,border=,flags=9,maximumSize=,minimumSize=,preferredSize=]
So my next question is, how do I get the index of a template within a repeater?
found it.
inductiveautomation.com/forum/v … dex#p54279
