Pasting from notepad++ to editor issue
Hi All
When working on a larger script i usually copy the script from ignition to notepad++ so its easier to see the formatting. When pasting back from notepad++ to ignition quite often i see that formatting has changed (indentation) which sometimes is easy to notice and gives error but other time tricky to spot and very dangerous.
Does anybody else have this sort of problem or maybe a way to workaround this?
Regards
Place a # in the leftmost column in the Ignition editor and paste below it.
Or always paste the entire editor content.
Yeah, the editor revamp can’t happen soon enough. ):
Thanks Phil, that is the solution until revamp
This even happens when copying from within the ignition editor. It's annoying.
When pasting, make sure that the line you're pasting into is completely blank (no tabs and no spaces). That usually works.
