Pdf viewer activeX not showing file
I am facing a problem with pdf viewer. They day I developed a page with pdf viewer activeX control in it. It was working fine.
What I had done is taking varbinary data from SQL and linking it with the viewer path. and when I hit run I was able to see pdf file properly.
But later night I got pop up to update Adobe pdf , I clicked ok and it updated my Adobe. Next day when I run the same program I see the pdf viewer to be grey , not showing file at all.
I thought that would be problelm with update ,so I uninstalled that version and re install old version. But still my pdg viewer is showing only grey.
Is there some solution to this.?
Try downgrading Adobe PDF viewer to version 9.5. This should be available from their website. See if that works.
I have already downloaded 9.5. It doesn’t work
Ok, is this the PDF viewer that is part of the Reporting Module or the Adobe PDF Viewer that is part of the ActiveX Module?
Its Adobe PDF Viewer which is part of the ActiveX Module
And what version and bit are you using of Ignition and Java? Are you able to see the PDF document in the client and not the designer? In most cases the PDF will not show in the designer, unless it is in runtime, but will show in the client.
Try this pdf viewer. This is version 1.0.0, so feedback is appreciated.
Thank for your quick response.
I am using ignition 7.3.4
Java 6
I am not able to see pdf doc both in client as well as designer. Both shows up blank.
I tried to install the given module, It says faulted.
Looking forward for reply.
[quote=“jmehta”]Thank for your quick response.
Java 6
Looking forward for reply.[/quote]
That module is only going to work under Ignition 7.5.
What can be other possible solution for me.
The strange part is , it was working the day I implemented and there after not able to get it work.
I think the update broke something. I spoke with another user who has a very similar situation. The PDF viewer worked fine, he updated Adobe reader, and now it doesn’t work.
As stated in the users manual, the ActiveX module is provided as-is, with limited technical support.
We are aware of the improvements that are needed.
A possible solution is the PDF Viewer in the Reporting Module. The only downside is if you don’t currently have this module on your license.
I do have reporting module.
And when I try to put varBinary data in filename of PDF Viewer it shows java error.
What I basically wanna do is , show the pdf varBindary data from SQL into ignition.
I had no idea that the activeX pdf viewer was able to take raw varBinary/blob data and then display the pdf. Everything is usually passed by a file path that the component then loads and displays. If I'm understanding you correctly and you were able to pull blob data from your database and then get the activeX component to display the pdf then that is functionality I didn't know the activeX component had.
There are two solutions that I see here. The easiest would be to upgrade and then use the pdf viewer module that was posted by @nathan.
Option 2 would be read the blob data from your database, write it to disk as pdf file, and then try and use the Ignition pdf viewer to view the file.
Thanks,
Yes I have implemented 2nd solution. I does not wanted to save file on disk, But then had to implement this to make it work.
Yes I was able to pass blob data as string to filepath of adobe adf viewer.
