I have a project that is used at several work stations. The project has a PDF viewer component indirectly bound to the associated UDT file path tag for each station. When I save the project from the designer, which ever pdf I have open in the designer is what displays for all of the clients despite the fact that their bound file path is different.
For example, if I have foo.pdf open in the designer, then save, all of the clients will refresh and load the foo.pdf file even though the current file path of the viewer is bar.pdf
v8.1.14
