PDF Viewer will work without Reporting module license
Hai, I want to display some PDF files in my vision client, Is it possible to use PDF Viewer component in Vision without Reporting module license? As I am having license only for vision client module.
Just a thought - Technically its a vision component so it should do.
Thanks for reply, actually PDF viewer component is available in Reporting module only.
No, Vision components provided by modules follow the module license, generally.
You can get a limited report license, the price shown on the website is for unlimited but you can buy it at either:
1/5 - 1 report
2/5 - 2 reports
3/5 - 3 reports
4/5 4 reports
5/5 is then the price on the site and is ergo unlimited
I don't want any reporting functions here, I have some set of PDF files in my system which I need to display in vision client. Since PDF Viewer component is under Reporting module, I have doubt whether this PDF viewer will work in vision client without Reporting module license.
It won't work without the report module, therefore if you want to display PDF in vision, you must buy at least one (limited) report license. I think that means you can use the PDF component as many times as you want though, just actual reports (that you won't use anyway) would be limited.
You might be able to make it work with a webbrowser. That also requires a module, but maybe you already have one of those.
or convert your pdf to an image if you only need to display one page or something
TIL. Can you select a limited reporting license from the "Build Your Own Package" pricing selections on IAs website?
No, you must contact a sales rep.
