PDF Viewer with PDF stored locally
Hello again!
I am trying to set up a pdf viewer but I am getting a failed to load PDF File. I have the PDF file saved locally on the same pc that the gateway is hosted on. No matter how I enter the file path it gives me the error. I've read on other topics about the use of a Web Dev resource, is this required if my pdf is stored locally?
Here is how I have my filepath in the source property.
C:/Users/hmi_support/Desktop/P&IDs/Davis%20P&ID.pdf
I've also tried it this way as well
C:\Users\hmi_support\Desktop\P&IDs\Davis P&ID.pdf
Yes. Browsers don't allow direct access to local files.
Thank you for the quick reply!
I installed the web dev module and set up my file. However when I copy the mounted path to my pdf viewer source I still get the same error.
Tried this as i saw previous topic encounter the same error as me but it did not fix it for me.
http://localhost:8088/system/webdev/Edge/Davis%20P&ID.pdf
@pturmel’s BlobServe module handles PDF files.
The gateway service needs to have access to the folder where you placed files. The LOCAL_SYSTEM account that is the default for services in Windows has limited access outside of install folders.
The ampersand in the URL would certainly need to be encoded, too.
Not sure if this is a known issue or not, but I changed the name of the orignal PDF when I imported it to the gateway the first time. I deleted and reimported and this time I didn't rename it. This let the PDF open correctly.
Sounds to me like your new file name simply had invalid characters for a URL. Those need to be encoded, like you did for the space. It isn't a bug.
