PDFViewer and VideoPlayer not working
Has anyone tried to configure the VideoPlayer or PDFViewer in the recent past?
If so, how did you make them work?
I am using the Web Dev file resource feature but all its showing me is failed to load PDF file.
videoplayer
pdf viewr
There should be a project name in those urls.
@pturmel /Ignition_Training_Manual/system/webdev/Ignition_Training_Manual/analytics.pdf this still did not work
https://docs.inductiveautomation.com/display/DOC81/Web+Dev#WebDev-URL
Consider right clicking the node in the project browser and selecting "Copy Mounted URL"
Thank you all for the help. I will use a different component instead. I have/ and had tried all the suggestions above but it still shows failed to load pdf file.
