PDFViewer clear active PDF
I’m using the Vision -> Reporting -> PDF Viewer to display PDF’s loaded from a SQL Database as bytes.
I can load a PDF without issue, but I’m trying to figure out how to actually then clear out the loaded PDF at runtime.
I’ve tried this:
emptyPDF = system.file.getTempFile('pdf')
pdfByes = system.file.readFileAsBytes(emptyPDF)
try:
	event.source.parent.getComponent('pdfViewer').loadPDFBytes(pdfByes,'')
except:
	#This will create an error. That's ok.
	pass
However I get an ICEpdf error popup that I can’t seem to avoid. I’m fine with it throwing an error, I just don’t want to see it in this instance.
Is there any good way to do clear out the loaded PDF?
Have you tried using an empty list instead of an empty string?
Same error. This is what it displays
Which I get because it’s an empty file. I just don’t want to see the exception when I do this.
event.source.parent.controller.closeDocument(), maybe?
event.source.parent.getComponent(‘PDF Viewer’).getController().closeDocument()
@paul-griffith was correct first.
His suggestion also works:
event.source.parent.getComponent(‘PDF Viewer’).controller.closeDocument()
This worked like a charm.
Thanks!
Was looking for how to do this, and stumbled across this. It would be nice if this was added to the docs site, (plus if there's any other extension functions for controlling the view, that would be helpful as well)
