Periodically refresh Iframe
I have an Iframe that contains asp.net as its source and it gets updated with new data periodically. Looks like it gets a different session id for every update and says “ASP.NET session has expired or could not be found” when it get a new data.
Is there a way to periodically refresh the Iframe or source (the view) ?
You could use a Gateway Timer Script to send a message to all sessions, which would then send out their own message to update the iframe with the source you’d like to update.
I generally use AJAX calls from the browser in a timer loop to the server . Don’t know about Iframe
