Im a little confused…
Im moving a stand alone system( with mssql 2012 database) to a central gateway. (copied project and db and tags, moved/imported them) Both the proj and the db look fine but the project is not recognizing the historical placement. All my tags have the historical db set correctly but it does not write the historical table(s). And I get the below error if I try to trend from the existing data that I imported from the stand alone. Am I missing something to get my historical data in and then back out?
java.lang.Exception: Error running query:
TagHistory(paths=[[ignitiongatewaysw]SouthWeld/SW_AQT_1_IRCON], start=Tue Sep 10 16:30:41 CDT 2013, end=Tue Sep 10 16:35:41 CDT 2013, flags=0)@1000ms
On: SW AQT1 Add Pipe.Root Container.Group.Easy Chart
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$QueryExecutor.run(QueryManager.java:316)
at java.lang.Thread.run(Unknown Source)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: The SELECT permission was denied on the object 'sqlth_drv', database 'IgnitionGatewaySW', schema 'dbo'.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:313)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:287)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:244)
in what kind of scenario would permission be changed on that ignition table?
Justin
